Clutch Spring?
Hello Everyone,
I have a 91 DX 5 Speed. When I press in the clutch, the spring above the pedal squeaks. I have tried spraying it with white lithium grease and that silences it for about a day, but then it goes right back to squeaking. And it's driving me crazy! What is this part called, I'm going to try to order a new one from Honda. Thanks everyone for helping out.
Rookie, if it squeaks look very carefully to see if the pedal bracket assembly is cracked. Another source of oise may be the pivot bushing, it's plastic and can wear out.
