1990 Red RT4WD Vancouver WA
Well its about time I make a build thread! (I have been working on my wagon for about 6 months now)
On September 1st, 2011 I drove to Lacey WA to buy my 1990 red 6 Speed RT4WD
Specs when i bought the wagon:
185,000 miles.
All original inside and out, no wrecks, or anything like that. :wink:
Lowered on ebay coilovers on stock struts.
Stock motor, newer 6 Speed.
Missing rear tranny mount!
Froze up power steering pump. (and no ps belt)
Dented drivers side fender.
Broken drivers side corner light.
Red rally armor mud flaps.
Really a pretty good car, in very good shape except for the fender.
on the way home:
The wheels that the wagon came with:
when i got the car home washed and waxed, with a rack i had laying around:
«13456710
  • 90 RT4WD (Cody)90 RT4WD (Cody) Senior Wagonist
    Soon after i wanted to rebuild the front+rear suspention
    Here is a long list of what i replaced/changed :D
    NEW:
    rear tranny mount
    Front engine mount
    ball joints
    upper control arms
    lower control arm bushings
    both fron axles
    new front brakes (disks+pads)
    sway bar links and bushings
    Oem SI manual steer rack with power steering delete.
  • skitsoskitso Wagonist
    Love those wheels on a red wagon.
    Were all the replaced components OEM or did you throw on some after market goodies?
    Things i have installed on the car since I have owned it...
    I painted the wheels yellow to test it out...
    not a fan of the yellow.... so i bought some super clean LS Wheels for $250
    Tinted the windows 20%
    Passenger side mirror (the last owner gave me the original one) Then i sold the mirror delete that was installed for $30
    All four Stock RT4WD mudflaps Thanks to Nick!! (503wagon)
    New JVC CD player with some pioneer 6.5" door speakers
    4,700k HID kits Hi and Low beams
    Suspention mods:
    New KYB civic Hatch Struts paired with Skunk2 Sleaves that I bought off of craigslist....
    Rear camber kit
    I was tired of scraping and wanted to be able to use the car as it was intended!!
    It rides really good! heres how it sits now:
    www.civicwagon.com
    Cleaning the carpet...
    Thanks! i didnt like the wheels they were in bad shape, and not a very good paint job, lobved the color though!
    and the bushing and rack were OEM honda.
    Other than the struts and skunk2 springs all oem stock componits. haha :)
    Well about a month ago i did a full tune up
    parts:
    fuel filter
    Changed rear diff fluid
    Cap+Rotor
    plugs+wires (NKG)
    Lower spark plug tube seals (orings)
    Valve cover gasket set
    PCV valve
    most all the vacuume lines
    Then a Powedercoated Black hammer finish valve cover, and heat sheild.
    Pretty much All the top end seals.
    Timing belt. New radiator, Water pump... all at the same time! its running smooth!
    Also got a new Corner light!
    Rack! Tax time came around and i bought a Yakima Rack for the wagon :)
    For everything i paid $255 + $5 in stickers hahahaha :lol:
    The rack fit very nice and sterdy too!
    My shifter bushings were very worn out, and loose so looking around the junk yard, i noticed that in a 1989 honda prelude(that also has a cable shifter) has the same small bushings at the end of the cables (at the shifter end)
    So i got a few of those bushings and picked the best two....
    Also out of a Donner RT I bought the shifter assembly to play around with haha :lol:
    I cut out 1.25" out of the stick, and welded it back together...
    It defiantly feels so much better !! :)
    also i like the shorter stick too...
    Well last week I started noticing that the wagon is needing a clutch... also the rear main seal, and pan gasket are leaking oil pretty bad... so i called around for parts, i also called a small shop in Longview Wa named "Acur-it" they only work on older Honda's and Acura's... He said he would do everything + A new OEM Flywheel for $700 so i thought hay that's a pretty good deal!
    So.....
    Here it is in their shop!
    :lol: I bought a really Clean set of Shuttle mudflaps for $92
    I am not sure what i am going to do with them haha
    Also random, but gotta love the PDX Meets!!! :D
  • lecoqlecoq Wagonist
    Good job so far! Keep it going!
    Thanks!
  • I personally liked the gold wheels on it better than the other wheels. But your wagon looks super clean! keep up the good work
  • Cody, love the car and all the things that you have done. Wheels and the rack are sweet on that. Keep up the good work. Thanks for the defrost switch and the relay, they work great.
    Good, glad to hear they work! Love when it's just a simple fix
    Update:
    The wagon is on jack stands in the garage on jack stands right now.... The wheel bearings I installed when I bought the wagon have taken a shit on me! (well only one side) but I went and got a set of SKF bearings, hopefully will be installing those at work sometime this week, I can use the press there hahaha Also I am still looking for some rt wheels, but I bought a full set of the center plastic caps off rt wheels today, No cracks, all in good shape, they are mint! $45 :wink:
  • What a delicious lookin ride...the paint is so nice and clean bro...anyways...keep us updated...love see these build threads.
  • PavementwagoPavementwago Senior Wagonist
    Love how red looks great waxed.. u gonna make it out to forum fest
    Thanks guys! Wand when and where is forum fest?
    PIR June. Check meets section
    The wagon is back on the ground, new wheel bearings, and one new inner hub, it drives great!! Also put on a roof cage! Pictures soon!
  • 503Wagon503Wagon moderator
    pictures now.
  • WagoDanWagoDan Wagonist
    Good job! love the wago meet, I had one too, well my three and mr horsepower's one :roll: , still looking for more owners in Colo springs area tho... :lol:
    Hay thanks sir, and you have some great wagons there!
  • MattKoMattKo Wagonist
    Nice ride. I'm not normally fond of the color red, but it looks good on your wagon.
    Update: I am still searching for that bracket I need, other than that nothing new, although I did buy a set of original RT wheels with caps for $200, I think I am going to have then powder coated? Idk? Maybe just some good paint haha
    Can't wait!
    Looks like Slo88crx is going to sell me the mounting bracket that I need! Hopefully this weekend
    Can't wait!
    pretty soon, we are all going to be rolling on stockers :mrgreen:
    theres a guy on cl that does powder coating. i think it's $45 a wheel. check out his site powderchrome.com
    i think i'm going to have him powder chrome my bbs wheels.
    that include stripping them?
