Low clutch engagement
My clutch seems to have two engagement points. It will start pulling the car forward just a millimeter above the floor, and then it will really engage a couple inches higher (where I would expect it to.)
Is this normal for the 4wd clutch or is there an adjustment to be made?
It should be about a inch(25mm).
Does the 4wd have a hydraulic clutch? Maybe I need to change the fluid. I know my CRX is a cable clutch, but it feels a lot different.
