auto rt trans ?
Freek
Wagonist
this is my problem one of the wires has broken what is this exactly so i can get anew or attempt tofix
Freek
Wagonist
Your pic doesnt obviously show what the issue is, I assume all the unplugged wires arnt what you are talking about but possibly what looks like one of the soleniods has a wire snapped next to it?
No disrespect NZ-DB8R
Two: The Z6 intake mani is flows way better than the A6, I believe there is a way to use the Z6 w/o wiring up the Vtec. I would look on dseries.org, it's been covered a million times over there.
None taken I just use that method when its a little awkward to get at
But yes the method you describe would be better
hmm....I solder differently
I split the wires and twist together (like a braid) the i place a small amount of solder on the iron and place the iron on the bottom of the wires. I then place solder on the top of the wires and within a split second the solder is pulled down into both wires filling up the empty spaces. This is the best method that i have used in joining two wires together.
