Engine Troubles - Updated
So I was driving to work today and all of a sudden as I was coming out of the exit my motor just shut off. The Oil light came on and the Battery light also came on.
It would crank but wouldn't start. Eventually the battery died while I waited for the tow truck.
Any suggestions? :?
Thanks
Any suggestions? :?
Thanks
Thanks
I'll post updates.
Thanks again
Thanks again
I thought the idle was too low but its not that. Could it be a sensor? The only think I didn't change when I did the tune up was the spark plug wires as they seemed to be in good condition?
Any suggestions?
I found this link: www.honda-tech.com/zerothread?id=1575913&page=1
going to try it tomorrow & see if it works.
Thanks again.
My B16 was doing that, and it was a combo of MAP sensor and AIT semsor..
Are you throwing codes? If not, I doubt it's causing enough problems to mess the motor up..
Maybe the timing on the dizzy is off? I'd adjust it.
Any suggestions? Please?
Have you tested your IACV and FITV?
Thanks
Check your ECU for cods!
Cheers!
I come from the DSM world and those cars are notoris for blowing them. The symptoms you describe coenside with what I experienced with a leaky intake manifold gasket.
good luck man, hope this helps.
I had a similar problem with mine. I finally figured out that somehow, when the initial problem occurred, it did something physically to the plastic tip inside of the IACV. You can check for this by removing the hose from the air cleaner assembly, and plug it off completely. If the car idle settles down, then you will need to replace the IACV unit.
On mine the IACV seemed to work Ok, by all the tests I could find. I finally figured out it was only leaking, a little bit, but it was enough to cause the symptoms you've described. The replacement, used, did not leak any air through the hose from the air filter, when it was not energized.
Any other suggestions why it would give me an oil light? Someone suggested low or now oil pressure? What sensors would I check?
Any other suggestions? Thanks again to everyone who has given feedback.
check the ecu under the passenger side carpet. there is a light that will flash count. how many times and use the link to figure out what it means
Thanks
Anti-lag system
