Temperature Sending Unit Question
Anyone know if all wagons have the same temperature sending unit? (i.e. use one from a RT-4WD model, on my non 4wd, even though different engine?)
  • Yes. I used one from a Z6 i have to replace on a D15b2. FYI, I'm talking about the one for the gauge cluster, waaaaay up under neath the dizzy.
  • There are 2 sensors one is temp ending unit to the cluster it is 1 wire.
    The other is the ECT sensor which sends info to the ECU.
    Most D series motors are going to use same sensors/connectors.
