Third Generation Factbook (?)
(EW - Third Generation) Factbook
Thanks To:
USDM
Civic Wagon RT4WD
USDM 1987
Chassis Code: ?
Engine Code: ?
Drivetrain: ?
Civic Wagon DX 4X4
USDM 84-86
Chassis Code: ?
Engine Code: ?
Drivetrain: ?
Civic Wagon 4X4
USDM 84-86
Chassis Code: ?
Engine Code: ?
Drivetrain: ?
Civic Wagon DX
USDM 84-87
Chassis Code: ?
Engine Code: ?
Drivetrain: ?
Civic Wagon GL
USDM 84-87
Chassis Code: ?
Engine Code: ?
Drivetrain: ?
Civic Wagovan
USDM 84-87
Chassis Code: ?
Engine Code: ?
Drivetrain: ?
JDM
    Does anyone have a photo of each different model?
    And having the rest of the information filled in would be nice. Post it up if you have it.
  • 85Si85Si Band Wagon
    84-87 Civic Wagon / Shuttle
    In the US it came with a 1.5L carbed SOHC engine, 76hp
    Overseas it came with an available 1.5i fuel injected motor, 91hp, called the 55i if I recal.
    It came as a Front wheel drive vehicle, and in 85-86 came with available pushbutton 4WD using a switch, solenoid, and electronic and vacuum controls to engage an actual driveshaft to engage the rear wheels. On demand push button 4WD.
    In mid 86 to 1987, it was switched to an automatic system, no switch. When the front wheels lose traction, drive is transmited to the rear wheels temporarily to assist.
  • Gasoline FumesGasoline Fumes New Wagonist
    USDM engine was the EW1, which was given a D-series code in 1987. I think the injected JDM engine was the EW5. Both were CVCC engines.
    1984-85 had recessed sealed beams, 1986-87 had flush headlamps.
    2WD and 4WD had different bellhousing bolt patterns. 2WD shared the bolt pattern of the other 1984-87 Civics and CRXs, while the 4WD shared its bolt pattern with the 1986-89 Integra.
    1984 Wagon specs:
    Most of it applies to all 1984-87 2WD Wagons.
    Engine:
    1488cc 12-valve
    76 HP @ 6000 RPM
    83.9 lb-ft @ 3500 RPM
    Aluminum block and head
    Suspension:
    Front - Torsion bars with struts
    Rear - Trailing link with beam-type axle
    Sway/anti-roll/stabilizer bars on both ends, rear bar was inside beam axle.
    Dimensions:
    Wheelbase - 96.5"
    Length - 157.1"
    Width - 63.9"
    Height - 58.3
    Curb weight - 2015 lbs (manual transmission)
    Colors (ext/int):
    Greek White/Red
    Suede Beige/Beige
    Stratos Blue/Blue
  • 87WAGOVAN87WAGOVAN Band Wagon
    My 87 wagovan 2wd has a D15A2
