after market roof rail
I found this and thought i would share it with you all.
made by Surco products, inc.
if you dont have the oem roof rails and dont like the ones from yakima and others. i found a company that makes roof rails that will fit right into the gutter of our wagons. i have not used them or even seen them in person but i might get a set. these are nice.
http://www.racksforall.com/index.asp?PageAction=VIEWPROD&ProdID=1784&zmam=2014894&zmas=1&zmac=4&zmap=SUR_R5300
http://www.accessconnect.com/safari.htm
there are three sizes.
If you do not have a factory roof rack installed or stand up pinch weld gutters on your vehicle, you can do a custom installation with the rails listed below. ( use a CH100 with these applications)
R3600 - 36" Mount Roof Rails (pair) $59.95
R5300 - 53" Mount Roof Rails (pair) $72.95
R6200 - 62" Mount Roof Rails (pair) $84.95
Aluminum rails attaches to any roof
Durable black powder coat finish
Special hardware kit included for easy installation (drilling required)
For proper size refer to application guide
is it the one that goes in the gutters?
i found some threaded holes in the gutter area. guess its for the oem rails or bars.
