Very Odd Clutch issue ( car moves with the clutch push in )
so yesterday while i was driving and went some where to eat, and after i was done eating went to start the car with my foot on the clutch and started the car and it would not go in to gear. So i turned the car off and put it in 1st gear and started it with it in gear and it took off like the clutch was engaged and moving the whole car forward with the clutch in and brakes on.
so my question is where or what do i look at from here??
some people have said to look at the pedal assembly- ITS FINE
does any one have or have had the same issue???
any help would be great
Thanks
Justin
Thanks
Justin
Does the clutch feel different? Harder/easier etc?
Your clutch is not fully disengaging. Let's list all of the possible causes:
Broken pedal/pivot
faulty cable
loose or broken cable bracket at transmission
broken release bearing shaft
broken release bearing spring
faulty clutch cover (pressure plate)
Faulty disc/debris from disc stuck between flywheel/disc/cover
As you can see, only the first 3 items can be eliminated before removing the transmission for further troubleshooting.
9.23765 out of every 10 complaints like this one on this car are found to be caused by a failed or failing pedal assembly.
thanks for the heads up the pedal assembly is fine nothing wrong there......
cable is in tact and in one piece
cable bracket is fine as well
i truly think its the pressure plate to be honest
for now i dont have time to work on it and its just sitting in the garage and its being put up for sale as i dont have time to work on putting a new clutch in it
p.s. also resurface your flywheel or clutch will chatter on take off. If it has a pilot bearing in the fly wheel replace it.
Good luck!
Check the pedal assembly. It really is the most common failure.
