Bogging When Warmed Up. HELP!!!
ok, so i have an 88 rt with the stock d16a6 in it. i have recently pulled the motor and did an entire gasket set on it. it was put back together and dropped back in just recently. It will start right up everytime and runs and drives great when cold or first started. As soon as it starts getting close to normal operating temp its looses power and starts bogging really bad. Mainly in the 1000 to 3500 range. the exhaust seems louder and it smells like gas. the idle drops low to like 450. The timing looks right. ive cleaned out the sensors on the intake. heres a list of new parts put on...
-Fuel Filter
-NEW Distributor
-Plugs
-Wires
-Thermostat
-02 Sensor
-Injectors(Junk Yard)
-Timing Belt
-Complete Gasket Kit
i really wanna get the wagon goin strong again, any ideas?? Thanks!
-Fuel Filter
-NEW Distributor
-Plugs
-Wires
-Thermostat
-02 Sensor
-Timing Belt
After the car is warmed up and starting to run poorly, spray some brake cleaner around the intake manifold. If the engine starts to rev up, you have a vacuum leak.
Can I ask why you replaced your injectors?
Also, you said timing looks good. Did you double check both cam and ignition timing?
Turned out my timing was off a tooth. I must've been looking at the timing marks at the wrong angle or something when I put the engine back together, but it was definitely off. I ended up fixing it the other day in about an hour and a half with the engine still in the car. Kind of a PITA, but it feels like a completely new vehicle now.
Also, if you do a leak down test, it will tell you where the leak is.
