rhino pac clutch kit?
its almost that time, clutch is adjusted to the max, anyone tried a rhino pac clutch kit? looks good, comes with pretty much everything but the flywheel. my motor is dead stock so i dont need anything fancy.. thanks guys
  • ZachZach Band Wagon
    What are the specs on it? Is it just a stock replacement clutch? If so, you will be fine.
    Light weight flywheels are a nice upgrade and can be had for fairly cheap these days. You might want to consider getting one while you have the tranny and clutch out. Remember, you will probably pay 30-40 bucks to resurface the stock flywheel anyway. So why not put that towards better performance?
  • I can get a new one for about 45$.. any lighter flywheels that are stock application for a different Honda?
    I dont believe there is a lighter sohc flywheel that is a factory piece.
