is there a 88 rt4WD header?
please tell me what header should fit the 88 rt4WD shuttle? Well, I used lot of time to search here and the older one forum, but I didn't find what exactly pass. Ideally something that I can find on ebay ;)
thanks
  • KomancheKomanche Band Wagon
    hmm?
    Item 1
    or
    Item 2
    ? thank you
    The 4-2-1 headers won't fit unless you modify them to collect into one pipe earlier on due to the clearance between the transfer case and the sump. Also some people have had issues with front cross member interference.get the spaces measured up and ask the sellers to take some measurements off the headers and that way you can be as close to fitting as possible.
    ok... thank you. what is the difference between 4-2-1 and 4-1 (yes, I know that it has another design :)) :?:
    :? Your item 1&2 are 4-2-1 headers.A 4-1 header probably looks like the 1 in your wgn.,but made of tubing.Here's a link a longer 4-1 header design:
    http://www.hondacivicwagon.com/board/vi ... c&start=25
    Make sure they say that it'll it'll fit a 4WD otherwise you'll lose out on the return shipping cost.
    :cry: I don't think there is a header made for the 4Wd Wgn.The problem is with the lower part of the 4-2-1 section NOT clearing the transfer case(transmission).
    :? There might be hope.I'm very close to finding a JDM 4WD header.Been researching for about a year.I haven't been trying hard 'cuz I've got other more urgent projects.S :( RRY.
    Thank you, I'll be watching your thread too...
    Are you after an aftermarket item or do you just want something that is 4-2-1? Because the stock SOHC ZC comes with a nice little 4-2-1 two-piece manifold which will clear the sump and transfer case.
    I don't know... I am looking for something better for my engine ;) than stock
    Got a pic of your current one?
  • I've got a 4-2-1 header on my 4WD. I can take some pics if you'd like. It is a chop and weld back up.
    Best pics I have at the moment is:
    Since I'm going boost I'll be selling it. Don't know what that might cost for shipping from the UK to Česká republika
    it shouldn't be too much... how much for it? :)
  • Iit's worth noting it's sized for a DOHC head so I think you had to work on the ports a little. Perhaps it's not. I can check when I remove it.
    I'd take £50 (€75) for it plus shipping, but I'd rather swap for some shuttle bits ie: headlight washers, rear outer light clusters, OEM 4WD wheel covers and so on.
