Mini me z6 Questions
I'm going to put on a Z6 head,dizzy and inake manifold.
I got a RT4wd.
Do all the intake sensors,dizzy, and the fuel injectors have the same plug in like a6 harness?
Also for the Vtec Soleniod do i have to get a z6 ecu?
I got a RT4wd.
Not sure about the sensors but if you want the vtec to work you need a vtec ecu.
The p28 is the z6 ecu.
a6 is odb0 and the p28 is odb1 you will need to convert your harness for the ecu
Getting a whole Z6 block!=]
If it were me I would replace the a6 harness and get a z6 engine and dash harness.
It may take longer to install but well worth it.
just keeping the long block on the side until i fully build it for boost.
thanks for the advice tho
This is WAY too much work.
Keep in mind that the z6 Dash harness wont plug into anything under the dash of the wagon.
Its much better to simply modify the stock harness a bit.
You will have to
1. swap injector plugs
2. delete resistor box
3. swap plug for distributor
4. plug in jumper harness
5. run provided wires for vtec and 4 wire o2 sensor.
If you do some searching, there are instructions on how to do all of these. Very simple.
