exhuast smoke?
So a little history for you guys. I baught my car from a very auto savy guy that could have done some pretty bad things to fix this car without knowing what he was doing. He told me the fuel pump was bad so just to be sure I brought a main relay with me when i went to look at it the first time. I put in the relay and it fired right up. The reason why I am saying this is cause I wonder how much gas and starterfluid the PO had dumped down the throttle body trying to get this thing started. Would sitting gas in the intake manifold eat seals? When I changed the oil it had a strong gas smell. wondering if dumping gas down the throttle body might have been associated with that. anyhow i changed the oil with 10w40 and noticed oil consumption was gone. yaaaah! but it still smokes. Ive driven the car maybe 400 miles now thinking that would be enough time for the guide seals to suck up some of that oil. also i did a compression check and got 135-140 all the way around. I am wondering in your guys opinion what you guys think it is. I am leaning towards guide seals but dont want to do it off of my not so experienced opinon.
thank you
thank you
Fuel can wash out bearings very easily as well.
Also a little trick if you have low compression and believe the cause is worn rings is to add a little oil in the cylinders then proceed with your compression test. Numbers should jump considerably, if not then look elsewhere, ie valves headgasket. Make sure you are testing with the throttle wide open.
