Boost issue =/ Help please
hopefully someone here can offer some ideas....
my build
a6 block with z6 head
stock length golden eagle rods
cp pistons
.53 trim garrett t3/t4 turbo
hks electric boost controller
2" ic piping welded only 5 rubber couplings
It all started yesterday morning when I started my car after sitting for a day (and ill add it ran fine the last time it was out with no weird issues). Prior to me parking it, I had the exhaust uncorked for about 3 days and when i corked the exhaust back up it still worked fine until yesterday.... Anyways, I got in the car and after it was warm i noticed it was only allowing me to build around 5 psi of boost. I instantly looked to my boost controller (which i have to turn down when the exhaust is open as it likes to build more boost) it was right around 1/3 of the way max which is where it normally is. I turned the controller off, because this would utilize the 7 lb spring in it and i was only around 4 pounds of boost. so i turned the controller back on and cranked it up gradually. When it was on max the car would only build 7 psi of boost and even that feels sluggish.
I checked the turbo and it spun easily with little to no shaft play, then i looked into all of the piping and didnt find any leaks.. I dont know what else it could be as the car runs just like normal it just wont build boost.
Any ideas are appreciated.
Thank you,
Torey
my build
cp pistons
Thank you,
Torey
