A/C issue
I got in my car today and the passenger side carpet looked wet, i called my buddy up and he said it could be from the A/C. has anyone had this issue before and if so can you point me in the right direction to solve the issue. thanks in advance for your time.
    It's not AC.Was it raining recently.It's leaking in from the vents at the outside lower windshield .Need to remove cover & replace splash shield(Not part name).I need to do it to mine.It's the same prob with teg.
    Good time to go Mono Blade(lighter weight,better mpg ,less maintenance & better looks).
    Temporary solution:
    1)Park pointing up hill or under a tree or carport,garage,etc.
    2)If parking down hill.It almost has to be flat.
    3)Car cover.
  • Or heater core. You may have a small crack. Does it smell like coolant?
  • I'm having this same issue with my wagon, definatly notice it everytime it rains! If i turn my blower on after a heavy rain storm, i can literally see a stream coming from under my glovebox on passenger side. The stream only lasts a quick second but my floor is soaked! Can anyone post pics of what i should be looking for to fix please?
  • If its getting wet when raining its probably the windshield seal. To test, have a friend soak the passanger side of the windshield while you look for the stream of water on the inside. Good Luck.
