Tips on installing a half size radiator
I need a new radiator and am thinking with how close the header is to the fan a half size would unclutter that area. It looks as though you would have to make some sort of bracket to hold it in and would also have to remount the AC fan.
Has anybody done this and could give me some pointers?
    fullrace makes one for the ef. not sure if you have to use their traction bar though. check out their site full-race.com
  • You need an aftermarket crossmember with lower mounting position or modify your current oem ones. The halfie is about 2 inches taller than an 88-91 civic radiator. Some people cut out the support that the stock holders are mounted to and just wedge it in there. It looks terrible though. The CRX HF radiator is physically thinner and lighter than any other 88-91 radiator. If that's your intention. You would need the HF lower radiator hose though, it has a smaller Inner Diameter on the hose and radiator inlet.
  • AbideAbide Council Member
    http://www.full-race.com/store/engine-c ... iator.html and it appears that you do. still dont know why someone hasnt made a dropin yet. the go autoworks look nice as well
  • DarinDarin Wagonist
    its a real pain in the ass.i just made a trac bar with a half rad and to get it all working properly with the trans mount sucks.then there is minimal room for down pipe/header.who wants to spend 350 on a full race rad?not me.oem fan and shroud cools the best.
  • esi42esi42 Band Wagon
    Without an aftermarket crossmember, they usually have a 'gangsta lean'.
    I run an Innovative crossmember in my crx. Has mounts for an EG half size.
  • Get creative...
    this shows the clearance needed for the heim mount.
  • pdcpdc Band Wagon
    It looks like you took only about 1/2" notch out of the radiator. Seems like the "gangsta lean" in the previous post was extreme for that small difference. I'm not leaning towards any lean.
    Nice work. I like it.
  • Prish! It has a 1 off crossmember. your fitment may vary.
  • danzdanz Wagonist
    heres a pic of the bar we did for darins car
    half rad fits like a champ
  • pdcpdc Band Wagon
    Seems like the size need for these wagons is common enough that there would be an aftermarket sized for them.
