map sensor wires location?
there is nothing plugged into my map sensor,
and i have no idea where i should be looking, d15b2 block, z6 head, no map sensor wiring,
please help.
please help.
that should be a link to mah photobucket. havent learned to post pics yet sorry.
You DO need to use that TB-mounted map, because the firewall one no longer has a vacuum source.
whats IIRC???
sorry new to this forum.
the car also smokes like it has burnt piston rings, but im hoping this map sensor issue will help to fix that,
there could also be a vacuum hose leak somewhere, but i cant seem to find a diagram for a d15b2/z6head.
If
I
Remember
Correctly
but still blows smoke, effn rings, so im looking for a new motor/block, thanks very much for your help!
