is there a list for all the lowering suspension that work on
the 4wd wagons?
since i read somewhere that the 4wd wagons dont share the same suspensions as the 2wd versions.
The RT4wd just has a longer spring, if you don't care about it sitting lower then swap in the same as what applies to FWD wagons.
