vacuum hose diagram needed...
I just picked up a 90 wagon has 161k on body and 90k on a d16y8. Who ever did the swap didnt hook everything back up...
(vacuum hoses, PS pulley, wires left open) :?
So, If anyone has any info or pics on what this engine is suppost to look like put together right, please let me know. Thank you in advanced. I plan to completely remove the PS system all together.
    or
    Good luck!
  • hey thanks alot man...hope i can get all of the vacuum back to normal...i have a slight issue with the idle..seems like a small misfire...has new plugs, wires...cap and rotor look new but not sure.
  • No worries.. After fixing the vacuum stuff and u still have a small misfire check the valve lash.
  • what is the valve lash... sorry im just new to hondas. i try and do most things myself so i can learn. but thank you again for the response
  • Unfortunately I work on cars for a living. :) Valve lash is the gap/distance between the rocker arm and the valve stem. Most people say "adjust your valves" or "do a valve adjustment". Too tight or too loose will cause a misfire.
    This will help
    http://thelic.org/users/tomo/ValveLash.pdf
