ok so i know my 1990 rtrwd wagon has a cable shifterer and not a linkage shifter like the other ef's. my question is, does anyone make a short shifter for our rt4wd wagons?
im cutting the stock one down and re-threading it and im mounting the shifter on 2" pegs with poly bushings i had left over from my energy suspension kit. Im also building a lockout that will only let me go into 1st and 2nd so that while im banging gears autocrossing i dont accidently hit SL or 3rd which sucks
please elaborate 8)
Short of a custom shifter is to cut the shifter shaft shorter & rethread as turbo_teg said.
