z6 into AWD wagon questions
does the z6 have the back of the block tapped to accept the AWD wagon midshaft?
will the stock z6 oil pan work with the AWD transmission?
Unfortunately this is not entirely correct; most D16Z6 we have come across have the bolt holes but they are not tapped. Easily fixed.
And the sump will need to be from the RT4WD D16A6.
http://www.hondacivicwagon.com/board/viewtopic.php?t=2131
