Starter motor remove Help please
Help please :)
I can not see the other screws on the rear
sample photo please
  • crxedcrxed Band Wagon
    Your starter motor is on the bottom left of your picture.
    So the other bolt should be beneath that
  • after you remove the s terminal (spade connector) . and then the big wire that is held on by a nut (Batt +) there are two bolts one on each side that hold it on kinda looks like this if the "o" was the starter and the "." 's were the bolts. ----> .o.
  • danzdanz Wagonist
    its down there. might be easier to see it from the passenger wheel well.
  • G-powerG-power Band Wagon
    Thanks all :)
