what warning light/symbol is this on?
hey guys. my shuttle didnt came with service manual. been searching on google but couldnt find any answer on this. just wanna know what is this warning light/symbol (most left-beside the battery)
thanks in advance. hope i posted it on the right thread.
  • my guess would be overheat but lol not sure . imma go and google this i have never noticed it. what year and trim of shuttle??
  • CasiCasi Wagonist
    only jdm cars have that light its for the catalysator-but its only for a few seconds on when you put the ignition switch in or is it lighting while you driving?
  • it lights up when u put the throttle on. very strange.
  • That light is to let you know that your catalytic converter is overheating and possibly not functioning properly or that you have another problem causing your cat to overheat.
  • CasiCasi Wagonist
    check out your lambda sond or you have a hole in the header so that fresh air gets into the exhaust and you have more air than fuel in the burning room-the sond /sensor maybe send wrong results to the ecu
  • CasiCasi Wagonist
    Please do not double post
  • I have heard of cats over heating due to being clogged. try to remove it or replace it.
  • ooohhh. thats why, coz i removed my cat conv. thanks for your help guys!
  • DD Wagonist
    The joke back in the day in regards to this symbol was... 'you just smoked a chevy'.
    sorry, had to.
    There was a sensor in the cat convertor, just earth out the wire that was connected to the sensor and the light will disappear
    is this bad for the car? any effects on it?
    If you removed your cat converter its not bad for you car. All that light means is the converter is overheating.
