Fuel Hose kit
Hi guys,i've noticed that my fuel hose is very old and crappy and i would change it.I've searched at Honda but they 'haven't it anymore in stock.On my EG6 i've installed a Russell SS hose and i would do the same thing on the Shuttle but i can't find nothing.Have you got some suggestions? :mrgreen:
  • delsol8017delsol8017 Band Wagon
    You could switch over tho a/n lines and fittings. Its not too pricey depending on with brand, size, and color line you go with. You can also tuck your fuel lines if you decide to go this route.
    Another option would be to just buy some bulk hardline from your local auto parts store and get a bender and cutoff tool. This way you can bend it yourself (a little difficult at times to get the right angles) and be able to still route the fuel lines like oem fit.
    DO NOT DOUBLE POST!
  • mtbikerTimtbikerTi Band Wagon
    Take your old lines to a hose supply store, they should be able to rebuild your hoses, and if they can't they should be able to make some new hoses. Should be a lot cheaper than buying new hoses from Honda.
