Pedal assembly removal
Clutch brace broke so I am trying to remove my pedal assembly, i have all the bolts against the firewall off, cotter pin and nut removed from the brake and clutch pedal out, but for some reason it still wont move. What else exactly do I need to do to remove the assembly? pictures or links on where I can find more info would be appreciated. I have searched on forums and on the web and have been unable to find anything.
Unbolt the steering column from the dash, leaving only the u-joint attached. lay the column in the floor.
Pull down both of the black HVAC ducts and remove them.
NOW take out the pedal assembly.
There is my how to thread. That pic is the bolts under the HVAC ducts
EDIT: Maybe I'm thinking of a different bolt.
