starter problem
Freek
Wagonist
my awd swap i put in. i swapped z6 with 90 dx 1.5 clutch and flywheel and i had to use the starter off the 2wd. it wont line-up is there actual starter that belongs withe awd tranny?
Things that come to my mind:
Is the starter from an automatic?
It's also possible, but I'm not sure, that the 4wd and 2wd starters will be different...
