Shift Linkages!!! Please help ASAP!!
So I'm looking to buy the M/T shift rods and such (not the linkages) and the regular Civic and Wagon have different rods. Are they the same with different part numbers? If anyone has the shifter setup from a wagon please let me know, I need them really bad because I'm fixing to install my B16. THANKS!!
  • jeffsciv23jeffsciv23 New Wagonist
    i thought you needed to modify a shift linkage from a DA integra? i'm about to install my gsr into my wagon once i get all my parts together and from what i understood is i need to cut 2 3/8" out of the straightest section of the linkage for it to work.
  • You have to modify whatever linkages you got to fit it. No one makes a kit.
    i have both shift rods from an 88 CRX sitting outside my house if they will work let me know.
