Car keeps cutting off while driving
Hey er'body. I'm having a problem with my wagon, and I am clueless as to the reason.
The Car: 91 2WD Wagon, D16Y7 swap with D16Z6 Intake Manifold, OBD0 SI ECU, DX Cable Tranny
Here's the problem:
While driving, my check engine light comes on, then my car starts coasting. The car is on,
but when I press the gas, it just grunts a little, but nothing. Then my battery light comes on, and my car cuts off.
Then I coast off to the side of the road... while I wait for a few minutes. When I try to turn back on, it just acts like
it's spinning to turn the motor, but it never turns over. After a few minutes, it'll turn over.
I checked the codes, and I am throwing codes: 17, 7, 15, and 16 in that order.
My speedometer isn't working, so I know that is why I am throwing code 17.
This happened a few days ago, and my car now cuts off at random while driving.
My car is running fine while it's driving. It accelerates properly. It stops, idles, goes, everything fine.
Before this happened, the only code I'd throw was 17.
I thought it might be a faulty main relay, but when I changed it, there was no success.
Also, if it means anything, when I first crank my car, I smell a little gas. I live in SC, so I do not have catalytic converter.
Please.... help me. :(
  • i have one solution you can try i had a similar problem with my eg once try replacing the ignition switch on the back of the key tumbler its the white round piece held on with 2 small screws that powers ever thing in your car .. try that and let me know
  • Next time it happens, you could try to pull the fuse for the ECU to reset it. On one occasion my old EF did this and i reset the ECU and that was the end of it. I have no idea what the problem was.
    Does it seem like the car runs when its cooler, but once the engine heats up, it dies out? I have had this scenario several times. Its usually the Ignition Control Module inside the distributor. They go bad sometimes and when they get hot, they won't work at all. Then they cool a bit and it will run fine.
  • BTW I just noticed you're in Rock Hill SC. I'm not far from you, in Winston Salem NC. I may have extra parts if you need them. What distributor are you using? OBD0 Si from the A6 motor?
    first off its best to find out what those codes are, they can pinpoint in the right direction..
    Code 7 - Throttle Position/Angle Sensor
    TPS sensor input is used to determine when the throttle is:
    Idle
    Wide Open Throttle (WOT)
    Rapid Movement
    During these conditions the ECU makes changes to the injector Pulse Width (PW).
    The PW is widen slightly when the throttle initially goes to idle. Within a few seconds the O2 sensor will correct the mixture.
    Closed Throttle Input (under .5V), engine RPM is above 1100, engine is warm. The fuel injectors will be shut-off (used to conserve fuel). Peeps with A/F Ratio Meters will see this happen, when the gauge drops to full lean, or no reading at all.
    When Wide Open Throttle is detected the PW is increased above normal fuel delivery. This is also known as "Open Loop" operation, when the ECU ignores the output from the O2 sensor.
    With Rapid Throttle Opening the ECU is watching the TPS input voltage for rapid changes. A sudden rise in the voltage would mean the throttle was opened quickly. So the ECU would increase the PW momentarily. As soon as the MAP sensor senses the drop in vacuum, it will take over.
    Testing - With the Key On, Engine Off hook up a voltmeter to the TPS. @ idle (closed throttle), voltage should be close to .5V and @ WOT (Wide Open Throttle) voltage should be 4.5V.
    The best way to adjust the TPS voltage is @ idle (closed throttle). While Key On, Engine Off, hook up voltmeter between the yel/wht & grn/wht and observe reading. If it needs to be adjusted, loosen the TPS mounting and move the TPS until voltmeter reads close to .5V. The check engine light will let you know immediately whether you missed up or not.
    TPS Sensor Wires:
    1 Red/Blue
    1 Green/White
    1 Yellow/White
    Code 15 - Ignition Output Signal
    Something is wrong with the referance voltage, the ECU is receiving from the igniter.
    The only way to check this, is with a Volt Meter of some kind, or ocs-scope. The latter being the most accurate. Sooo, that means a trip to a shop, that has this kind of equip...
    Most peeps just end-up replacing the dist.. However, you can DYI if you have the tools and manual...
    Code 16 - Fuel Injector
    Code 16 is probably the Main Relay, however it could still mean a bad Injector, Resistor Box tho.
    Most failures occur, when the weather starts heating-up for the summer...
    If the car refuses to start, but "turns over" on a hot day, try opening the doors/windows, and let the interior cool down. "Then try starting again". May not work all the time, but worth a try anyway. Also, would help in troubleshooting the prob, if it does start. Another place to look is the ECT sensor, refer to the above
    AintGotNoSol is right you have all the signs of a Ignitor :
    +++ SiWagon Freebie:Honda Ignition Upgrade:D
  • So, am I needing an Ignition Coil, or Ignition Control Module?
    Well, here is a video of what happens shortly after my car cuts off while driving. Hope it'll lead to an answer
    http://www.youtube.com/watch?v=OoG40MBMIQE
    And, here is a video of when my car finally decides to come back on, and then me driving.
    Notice there is no issues in responsiveness or problems while driving.
    http://www.youtube.com/watch?v=MD3-3K2ICYs
  • from my exp when the ign chip goes out it goes out ... dumb question have you checked to see if the rotor button is loose? but it really does sound like the its the ign switch behind the key that bolts to the tumbler i had the same problem with me eg and my ef 3 of them in fact ......they get worn out and the poper places get old and loose contact and slide back internally and loose conection ... try replacing that ans see if it fixes the problem first
    It's NOT the coil.It's called a Ignitor (Igniter Unit as Honda calls it).About the size of a matchbox w/a few terminals on it.It's about $60 from Rockauto or the whole dizzy for about a $100 more.
    Don't know what the Ignition Control Moduleis?
  • Finally found out what it was. My distributor (ignitor) was toast.
    Swapped out my distributor for a D16A6 one, then repinned it work with my square plug on my harness. Works flawless now.
    Thanks everyone for your help and for getting me through this horrendous occasion. Man it sucked.
  • Cool man, good job. Sorry i didn't get back to you about that distributor. I have been maaaad busy lately.
