I need help from you suspension gurus.
I have a set of Tein SS with pillow mounts installed on my wagon, and have run out of travel on the greased collar.
For the car to ride were I want it to the coil has to be so preloaded that the ride suffers. I would also like to raise it a little bit more. The rear is fine.
So the question I have is,
Do I put stiffer coils in the front or
Do I put longer coils in the front or
Do I do both.
  • cbothacbotha Band Wagon
    With coil over the spring rates are generally linear so preloading should not affect the ride.
    The ride will suffer if it is too soft of a spring so that you either hitting the bump stops or coil binding the spring.
    As you are raising the car I don't think would be an issue.
    I would get a longer spring.. The stiffer spring will not help your ride.
  • Mr GMr G Wagonist
    Hmmm, I wonder if they are binding. Thanks for the insight, I'll have to look into longer springs
  • Mr GMr G Wagonist
    Anyone else have any input??
  • JakerJaker familEE
    Longer springs.
  • Mr GMr G Wagonist
    Will longer springs it is.
    Now another question should I add a hundred pounds of spring rate to the longer spring for a the extra weight of a b series swap.
