Woodi ... I have to mount the tubes then send the guy the measurements for him to custom make the rack ... Ice sent him an email asking his opinion also ...
Rev.... I want the lights to fold down .... Here n VA the lights can't b wired or must b securely covered so that no light shines out if accidentally turned on if they r up like that ....
Ok gang ... So in is the win ....
I'm gonna grab some thin metal of some kind so I can use it on the underside.. Pinching roof and I guess use some flat washers, lock washers and nuts that won't ever come off ...
Oh and I night have another trick up my sleeve for my roof .... A coworker liked my filler panels and gas door ... Hint hint ...
O.k. I was going to do that same rack setup when I got my 1st wagon...
And, Now I know how good it would have looked... Now it is my goal to 1 up you on a few things...
Third - ((( In ))) For Sure.. Out looks retarded ( sorry to any handicapped users we may have )
Good Work man... Keep it up!
Hey hey ... no more drinking Haterade for U buddy....
it rides a slight bit stiffer.... but the front struts stay fully extended most of the time
now the rear .... im thinking of inserting a set of coil overs i have laying around to get it to sit higher .... looks 1/2 - 1 inch lower than front ..
it was a very easy OEM parts swap nothing hard @ all...
I vote "IN" for sure. Saw it in person, I think it looks good that way.
thanx sir... im gonna snatch out the head liner this evening or n morning i hope... and start making 6 small mounting plates for under the roof to pinch it up ..
ok so a lil update ....
the mailman dropped of my pistons and rods for the new turbo motor....
BUT ...
this morning while turning into work i had to slow down and let another car pass then when i proceded to turn Scrappy BACKFIRED horribly loud and with a great bang .. then stalled out ... i attempted to pop clutch as i was still rolling maybe 5-8mph ( studdered and stalled..) then i had to push him across 3 lanes of traffic and down into my normal VIP parking ....
ok no drippage and he turns over and attempts to start but will back fire sorta and nothing ...
any help or ideas r welcome ....
WELL SURE .....
I dont gamble, i work to hard for my cash but im glad u knew what u was talking about ....
Look what fell off n my hand as soon as i took off the cap...
Oh and whats wrong with this picture ..????
ok here is a close up..... Now how n hell did this happen ... ???
ok gang so this is my project since i just dropped of the 75.5mm vitara pistons & H Beam Eagle rods @ the machine shop....
ok so its a used and the previous owner took it apart for rebuilding ....
so im thinking since its been opened and all the parts out i might as well rebuild it so its fresh and new..
any ideas for a good shop to do a nice job..??
:twisted:
The bars look pretty cool facing outwards but the load would push them outward if you placed anything heavy up there.
x2.
IN
First - You Suck
Second - You Suck
almost makes scappy look bo legged with it out.
lots of work on that thing.
Can't wait to see how all this turns out
well between work and sleep im getting a little work done ...
just got the 2 1/2 inch exhaust done & ordering the 75.5mm pistons n the morning ..
BUT ...
take dizzy cap off and check rotor button.
If it is attempting to fire and also back fired.
sure sign of rotor button screw came out.
wow it could b something this simple....
the screws that hold the ignitor pretty much are seized in so now you have to try and get them out.
would suggest pbbaster etc.
I'd say put it back together get her home then take the dizzy apart if you have a spare car.
Rich
Chip, put the cap on w/ 2 screws and spray penetrant at the broken screw for a few days.
that was my next question.... but U answered it b4 I could ask.....
think Ur Brother is right ..... But U might b HCW's Yoda... and help to all n00b's
I am going to have to agree with him on that.. Bam you are HCW's Yoda...
:idea:
hints...
:arrow:
and a nice pic i like from back up the side....
