Zero Compression On Cylinder Two
Hey Guys,
I took a gamble and purchased a Rt for giveaway money, I should never gamble as I usually end up loosing my shirt, keep telling myself never buy a car unseen, after a Triumph Stag, XJS and RX7 I still have not learned my lesson :roll:
Anyway the car had a poor idle, it sounded like one cylinder wasn't firing so I replaced the plugs, no joy. While waiting for my buddy to return my compression tester he had for a lifetime I then replaced the distributor cap and rotor, no change. Ohmed out the spark plug wires, everything looked spot on. Removed the IACV and cleaned it all up, again, no change. Compression tester arrived and low and behold a big fat zero psi on cylinder two. The rest are 150 or 151 PSI (motor only has 130k on her). So, I think its safe to say its either a bent valve or a hole in the piston. Either way, I need to remove the head to see how bad things really are.
I had a few quotes from mechanics, all between $800 - 1000 for removing the head, replacing the valves, machining the head, changing the timing belt and water pump.
I need advice, are these reasonable prices? Central Valley California is where I am, any other Central Californian guys know a good mechanic? Removing the head looks easy enough, just time consuming, but I don't want to start something I cannot finish. Part of me wants to do it myself, a nice challenge....hmmmm....what to do.....
Thanks in advance!
Thanks in advance!
DO IT YOURSELF.
get yourself a Honda manual, that will be your bible on all repairs.
since the motor is shot anyway, i recommend you remove the head your self and check out whats wrong. if its the head, then just find one from the junkyard or used somewhere else. hell, i can get heads all day for $80 from my local junkyard. if its more then the head (such as a blown piston, ring, etc..) then just buy a complete motor. like i said, there are used JDM SOHC D-series motors galore for around $500. the DOHC ZC, my personal favorite, is a nice little upgrade and would bolt right in
it took me 2 days to swap out my first engine with NO power tools, NO engine hoist, and working alone. the second time i did it in 9 hours. its not very complex (not sure how mechanically inclined you are).
fwiw, the current engine in my car is a D16Y7 engine from a 1996 Civic DX that i bought for $100 from the junkyard during a sale they had. it runs perfect and doesnt burn a drop of oil. took a little bit of modification to make it work, but nothing that took longer then 2 or 3 hours (just the drivers side motor mount bracket needed to be swapped, timing belt cover needed to be trimmed, and 2 wires had to be extended.. simple stuff)
of course, we are here to help you along the way.
Get a genuine Honda manaul from Helms as opposed to the Chilton---It is well worth the extra money.
As for pulling the head- google away and see if you feel comfortable
As opposed to redoing the engine, I'd swap a different engine in. As it is an AWD search the forums on which engines will swap in the easiest.
Then go get some ATF (automatic transmission fluid), drop 2-3 spoonfulls into that cylinder, turn it over by hand again, 6-7 revolutions, and let it sit overnight. Repeat mid-day the next day (don't add more fuild) and let it sit again. Do this for a couple days and then start it up to see if the rings have become unstuck. Worst case scenario is you're out $5 for the ATF and 2-3 days trying to unstuck the rings.
Thanks for all the advice, really appreciate the time you took for the replies!
@wagondizzle - You convinced me, I am going to go ahead and get my hands dirty.
@str8shooter - I guess once I pull the head Ill make my mind up, if the damage is just to the valve Ill keep the motor, its low in miles for the year...swapping for something more sporty might be an idea but Cali and its smog laws are a huge PITA.
@ak_ef9 - Fingers crossed, $13 per valve seems like a deal, should I go with aftermarket or plump up the cash for Honda's?
@abotha - I ended up with a Hayes manual, never had much luck with Chilton, but never heard of Helms...might just buy that too...more pricey but appear to have great reviews.
@Jaker - I did try a wet compression test, made no change, but stuck piston ring is something I never really thought of...hmmmm. Ill pour a little extra oil down there and give it a try, thanks for the tip!
1 tight exhaust valve is possible,
2 timing belt skipped a tooth = bent valve. 100-130k is about the time the belt would.
3 carbon build up broke valve "it could, but rare"
4 rings too but 130k is low.
I personally had a d16a6 head redone 475 out the door. 800-1000 is crazy.
Edit---- Sea foam it, 8$ for the can at the auto part store, it will do what atf does but sensor safe and better results thats "my opinion". but it will clean all the carbon off the intake valves, piston tops and exhaust valves.
Ill pop the valve cover off this evening and give it a try....Ill inspect the belt too, If I were a betting man I'd say the belt skipped a tooth or two.
Check where the air is coming from!?
If you hear the air through your throttle body.
It's the intake valve.
If you hear it from your tailpipe.
It's the exhaust valve.
If you seee bubbles from your radiator.
It's a head gasket.
If you hear it from your dipstick hole.
It's from your rings.
Your rings could easily be aligned up to not hold compression.
