No Tachometer
every since i bought my 90 rt i've had no tachometer, it's always been dead. has anyone heard of this problem or know of an online source where i can find wiring diagrams for the tach?
thanks
    Check your Distributor connectors
  • gixxerkidd03gixxerkidd03 New Wagonist
    ill double check but i remember doing it when i first got the car. you know anywhere you find wiring diagrams?
    all the connectors look good im just not sure which pin is for the tach. :? the hunt continues..
  • NZ-DB8RNZ-DB8R Moderator
    Download a service manual for the appropriate year EF hatch. Wiring is the same.
    Just google "Honda Service Manual" or something
    did you actually swap the distributor? peterpanswagovan has a bad dizzy tach issue but all connections are straight, just a dead tach that will occasionally flicker when first started.
    i didn't actually swap the distributor. im going to down load a manual and test all the connectors first. plus i dont have an extra distributor. ill let you know what i figure out.
    i have a similar issue, my tach shows 0 when idling, but works soon as the throttle is applied.
    this happened after i washed the engine bay a long while back. i thought it might be my dizzy getting water in it, so i swapped it with a spare one. nothing changed.
    maybe the tach itself is messed up? i never bother to check that with a spare one.
  • JakerJaker familEE
    A flaky ignitor can f-ck with your tach. Usually it ends up bouncing around at 3-4,000 rpm, but other things can happen. If you have a chance to try a spare distributor, do that. If you can afford to buy a new ignitor, and the one in your car is of unknown age/condition, I'd go that route. However, buyer beware. I don't know of any auto parts stores that'll accept a return on an ignitor.
