What side head gasket goes where?!?!
well went to throw on the head gasket tonight and realized i don't know which way it goes... it is the one that supersedes hondas original gasket for the d16a6. Honda part # 12251-p01-004 multi layer metal gasket.
this is how i think it should go on
this is the opposite way
all of the forming on the duel color side is facing outwards..
the other side, all the forming is facing the duel color side.
i just don't know any help is appreciated!!
bowz
bowz
MLS gasket FTW.
if its upside down the tang will hang over the drain hole and if its right side up it will fit perfectly and there will be no overhang.
ugh i cant find a good pic, the head studs are blocking the tang im talking about...
edit; even easier is check where the water pump is, and make sure that the head gasket lines up with where the water pump is...
danz, i forgot to look before i bolted er down, maybe some one else will be as smart as me and not know how it goes and that lil bit of info will help them out!
thanks again guys!
bowz
