my new motor is here!!!!!
dont let looks decive u this non-vtec single slammer is the fox in sheeps clothing. eagle rods, arias 9.0:1 pistons, balanced, blueprinted, headstuds, AEM cam gear, aluminum crank pully, port and polished head, isky valve train, delta cam, and its got 10an fittings on the block and valve cover for a bad ass ventelation set up as well. ok ok ok i know its not new but its new to me and the guy i got it from says it has 4,000 miles on it just to be sure everything is cool im gunna pull the head and change the headgasket just so i can check it all out. i dont know when im gunna put it in i want to take my time and do it right like get a new clutch and get myself a breather tank set-up made. lookin to hit atleast 300-350hp on pump gas.....
