kylerwho wrote: for the 2wd wagons yes for the rt4wd wagons no
NZ-DB8R wrote: Now I havnt looked under a sedan or hatch but I was under the impression that the rear subframe is part of the unibody, not bolted on like a wagon.
Seems like an expensive way of fitting a cheapish part that you dont really need
2wd and 4wd wagon crossmembers are dimensionally the same. Only difference is the mount for the rear diff.
this is correct info.
