Head swap done, now no spark?!
okay guys, just wanted to get some opinions on what you think i should do, i've done a couple of tests to limit the possibilities.
here's my setup.
*z6 head
*z6 distributor (used) which i put new cap/rotor
*p28 ECU
*ZERG ECU and dizzy harnessess
my vtec is not wired up yet, only because i havent bought the plugs yet.
it'll crank all day, but no spark from the plugs. took off the dizzy cap, removed the wires from the coil. quick little light bulb test and it's definitely getting power.
probably a coil issue right? or do you guys think the igniter could be the culprate? thanks for any words in advance.
here's my setup.
*z6 head
*p28 ECU
@superhatch, unfortunately i haven't wired for the CEL yet. i still need a toggle switch for the CEL to blink my codes. if i don't figure this out soon i'll get that done and go from there on the codes. thanks for the info!
