Return to idle problem D16A6
Hi all!
I need your guys input on this matter!
I got this wier a$$ problem. When engine is cold it returns to idle after acceleration just fine, or should I say it drops proper amount RPMs to have a smooth shift. However, when engine warms up I get this intermitten slow(reluctant) RPM drop between shifts.
History: 180K miles, new T-belt, W/P, full tune up and full fluid exchange when I got it!
I suspect IAC ... maybe MAP is a bit slow?
I am too lazy to get my Fluke and Mighty VAC to propely diag MAP.
What do you guys think of it?
Cheers!
Cheers!
what is FITV?
Cheers!
Cheers!
I will check for leaks again!
I think it is TB gasket.
Thanks!
