Yay or ney rattle can roof
replaced the front motor mount -48
got rear motor mount-45
two cans of gloss enamel
two cans of primer
two cans of clear coat
80 grit
120 grit
1000grit
1500grit
no final wet sand of 2000 grit and polish yet but will do that this weekend..
+40
and i ordered led corner bulbs that was like 15
i also spoke to koni about getting my shocks revalved im saving up for a new set completely which will cost about 475 shipped which is better than koni direct with the warrenty kindaaaaaaaaaa disapointing koni..
im pretty drained i did all this off 3-4 hours of sleep and did a final spray after work just like 1 hr ago.. im pretty pleased so far, once i do a final wet sand and buff and polish i think it will look alright for the price, def. better than letting my roof continue to rust and look hella shitty.
im overall pleased. i think the roller method wins though in terms of loose aerosol and affordablility .
comments are welcome, hate all you want but like i said its better than rust .
two cans of primer
80 grit
120 grit
1000grit
1500grit
+40
I am pretty sure you wheels are on the wrong sides. I had similar wheels back in the day and the spin pattern is meant to spin the other way..
the cars blue
if you think about it the way the wheels i have spin in a way to fan the rotors
I can dig it... Goes with the stripe and wheels...
Now, need to find some sort of caps for those wheels though, even old steelie metal center caps would be good....
Different & that makes it cool..
feedback!
their local and the only one i know of that can do it around here its gonna cost a pretty penny im gunna rebarrel them to 8inches wide with a 3 inch lip or so. and get them widened to a 16" thats the only way ill be able to add a lip on that
Probably going to try this out.
