Idle issues
Ok im having trouble with a friends car. ive searched for a while and have found nothin that seems to help. He has 91 Civic Hatch its got and obd0 to 0bd1 conversion harness running a base p28 ecu on a d16z6. it has a lopey idle up to about 3000rpms. weve changed out the iacv, adjusted the fitv and bled the coolant system of air. the motor was recently rebuild with all new gaskets and i havent been able to find any vacuum leaks anywhere.
could someone please help me out here.
and the motor has an adjustable cam gear and the timing is set at 3 degrees advanced according to the shop that did his rebuild.
