Q: Injector compatibility?
I gonna replace injectors but I am wondering if I can use other injectors in accord or prelude for wagon 1.6L.
Can I use injectors in Prelude 93-96 part#06164-P0A-000 2.3L 2259cc (H23A1) or those in Accord 86-97 for CIVIC WAGON 1.6L SOHC (d16a6)? Is the injector in 1.6L wagon different with one in 1.5L wagon?
Thanks.
Thanks.
you will need low impedance 240cc injectors...
dpfi injectors are not compatible.
any obd1+ injector is high impedance. they will not work unless u delete your resistor box.
you need to find OBD0 240cc injectors if you can not reuse your stock injectors.
If these injectors are low impedance, will it work in 89 1.6L SOHC? or It should be low impedance and OBD0?
Thanks
but injectors are a funny thing.
injectors that flow the same, and have the same resistance, can also run very differently. i dont quite have the knowledge to explain it well, but just be aware that all injectors are not created equal.
that being said, they are both honda injectors, low impedance, and should flow the same. id say give them a shot if the price is right.
you could also try letting your current injectors sit in a bucket of mineral spirits for a few days and blow some compressed air through them.
