First timers rt4wd boost quest. Help me out?
Alright so here it is, I want to boost my a6. I've done my research but you can really only read so much. This will be my first dive into major engine internals and boost. :oops: Noob. I'm aware. Can't learn until you try though. Anyhow, I have a z6 head on hand, so I'd like to utilize that and I would like to do my first set up with stock internals just to keep it as simple as possible to start. My goal is mild, I'd like to see 200whp and keep it reliable and have a broad powerband not just topend. This is a wagon, will be my daily, and I want it to feel mildish. So)
Goal)
200whp w/ stock internals, stockish mpgs and reliability and a turbo that builds boost early.
Parts on hand)
healthy d16a6 in car
complete z6 head
p28
I've decided to go for a cast log manifold, will be running an intercooler, but I've hit a wall when it comes to turbo selection.
I'm on a bit of a budget, not going dirt cheap but baller build this is not. I'd like to run a stock turbo, I was looking at a 14b off of a manual trans. 1st gen. eclipse, or a t25 off of a second gen eclipse(I think thats right?) My thinking being that i'm not looking for huge power, from what I can tell those are on the smaller side, designed for a somewhat similar engine size and layout and with a rebuild will be superior quality wise to an ebay turbo. I can't find good info on the guts of the situation though. Using the zeal compression calc. I came up with a 9.72:1 CR using the z6 head and a6 headgasket. Is this a safe CR for what I'm after? I know leaving the z6 head off and just keeping the motor all stock will leave me at 9.1:1 so I could save the z6 head for later if need be. I'm considering just leaving it that way to save myself the headache of getting it all assembled then if I run into problems not knowing if its internal, turbo related or what else as this is my first time with this. Also what kind of PSI would I be looking at running with this set up to hit nearish to 200whp? Suggestions on what turbo to run would be helpful as well. That 200hp mark is just a number, not a requirement. If leaving the motor stock for now means i'll have to go lower hp wise to keep it reliable and safe, then i'm all for it.
Goal)
Parts on hand)
complete z6 head
p28
2. Use the Z6 head, that's 20% more hp than your A6 basically for free since you already have the head.
3. Use a thicker head gasket to get a lower CR on your mini-me back down to 9.1:1ish. 9.72 would probably be ok, but 9.1 is just gonna be safer. http://www.cometic.com/
4. Decide on your tuning. There are probably a TON of Chrome maps out there for a setup like yours. Probably your best and cheapest option.
i would run the t25 and you will probably run about 8-9psi to see that horsepower number but your reliablity is going down hill since its documented that the rods will bend around the 220hp mark.
I've got the parts, just like you, but I have a y8 head...and I'm trying my damnedest to figure out how to keep AC without doing lots of welding and funkyness...
Greddy has a kit that is ac freindly. Something t14/t15 ish
http://www.summitracing.com/parts/EDL-15031
http://www.edelbrock.com/sportcompact_n ... perf.shtml
http://www.summitracing.com/parts/EDL-15033/
Question: where do you guys buy turbo rebuild kits? I don't want to spend $130 and up on a rebuild kit..........sounds ridiculous to me. t25 is the one I have. And DSM injectors? are they plug and play on obd0 cars?
What size intercooler piping do you recommend? any links to something up my alley?
BAHH! I need you to help me figure out who sells the rest of the downpipe. I kept thinking it was just a stocker but I don't know. I really like the Civic EX with TD04H-15G 92-95 [GR-11550021A] Kit with the whole being ac friendly and looking fairly factory, but the price tag is a terror to even think about. :shock:
.......and what is this small modification to use DSM injectors? I have blue top 450s on hand...
