(turbo vtec)Thoughts(good or bad)
I'm looking into picking up a d16a6 short block this weekend. And i know danz has done it but his is n/a. I wanna make a turbo d16 stroker using the rotating assembly out of a d17. and ill be running a d16z6 vtec head.
Any thoughts or concerns that would make this hard at all.
You're just asking for a headache if you're an amateur
there is no down side except more parts to break and more things to go wrong. but its a honda, its reliable to begin with. so no worries.
dont forget to remove the oil jet before you bolt the head up. and dont forget to use a metal layer steel gasket. the composite ones are the devil!!
heres a dyno from my old drag motor setup. A6 bottom end, Z6 head, Colt cam
for the price of some weisco pistons and some forged rods, id really recommend going that route.
snap a rod, and u can easily take out the head, contaminate the turbos bearings, crack the bell housing on the tranny, etc.
i wouldnt want to push these little D17 rods past 250whp, but thats just me id play it safe.
heres a dyno from my NA D16 stroker i put together. D17A1 pistons, rods, crank... shaved my ZC block .030 to bring the pistons up to deck height. .027 Y8 head gasket. Y8 head with stock ports and stock cam. puts it about 11:1 CR.
not bad for a stock cam. 143hp/130ftlb to the crank
the journals on the crank are smaller on the d17 so you cant bolt on d16 rods.
should check out the d18 thread on d-series.org to see the stroker motor.
you dont need to machine the snout at all, if you use a D17 crank pulley and oil pump....
you should check out my thread on d-series.
i am only using the d17 rods/crank/pistons to "stroke" the motor out for more displacement. i am still using a D16 head and D16 block!
its a VERY easy build with the right components. no machine work required. but if u want a little boost in CR the deck of the block can be shaved .030 to bring the pistons up to deck height
danz is right on using a d17 internals and oil pump and seal. i was thinking about the process to convert the d17 crank snout to work with the d16z6 pulley and oil pump.
no a d17 head will not work on a d16 block. 2 oiling ports are in different places on the d17 block compared with the d16 head.
I am building a stroker ZC with the d-17 crank for my towcar. I have to use the d-17 rods, oil pump and pulley, right? This will save me a great deal of grief and time. Thanks for the info. I am using Vitara pistons at 76mm bore to get 1715cc. Do you set the piston crown flush with the block deck? I plan to machine the crowns down to zero deck height, but haven't measured the difference yet. Have been given a ZC block, 2 heads and bought a d-17 shortblock for $50. New Vitara pistons were $125, so DOHC stroker motor = $175! Cheaper than Crower, by Gum!
its up to you which way you want to go! i guess it also depends on what head you use...
edit; if ur going DOHC i think it would be wise to open the combustion chamber a little, to accept the piston. that way you will increase your quench. those DOHC heads have HUUUUGE combustion chambers and shit quench!
Read somewhere that you have to use a ZC lower cam gear to make this work, but it needs to be bored to fit the larger snout of the d-17 crank. Also something about the d-17 crank position sensor portion of the gear or pulley, wasn't clear to me which one. Is there an alternative to this, or do I need to use the ZC lower cam gear to get the right tooth count?
Planning to mill the head .05-.06 and use stock cams from JDM ZC engine I have located here in Dallas. This should help the compression, but I can still swap back to the stock (spare) head if I decide to go Turbo after getting the NA version going.
Thanks, Jesse
What I am currently trying to work out is if I can pull it off and keep the d16a6 oil pan. Since I have the RT4WD I suspect there would be clearance issues between the "transfer case" and the d17 oil pan.
I've been doing lots of research, on your build you used the d17 components and d17 pan. Doing some more digging I found this in the D18 thread over at d-series. Comparing the oil pumps and rear main seal between the d17a1 and d16y8 and the only differences being the D17A1 oil pump is lacking the dipstick hole and the oil seal opening is bigger all other things seem the same. Sql Civic also says
"The dipstick problem can be avoided altogether when using a D16Z6 block since it’s located on the exhaust side of the block. Another option is to machine a dipstick hole in the D17 oil pump and use that pump (the D16Y8 oil pan bolts up to it fine). "
Going further I found this thread on HCW where sonic has done a D16Y8 swap using from what I can gather a D16A6 oil pan and D16Y8 pump with the A6 pickup. So if the D16Y8 and D17A1 parts are essentially the same it should seem reasonable to assume I could use the A6 pickup on the D17A1 pump and make it work.
It seemed like in your build thread you didn't think that would work so I'm just trying to figure out why.
how is an RT oil pan different from a regular A6 oil pan?
the stamped steel D17A1 pan is VERY similar to the FWD A6 pan...
Seems like as long as there is no difference in the shape of the oil pan mating surface on the D17 and if the RT pickup will attach to the D17 oil pump it should work.
I'm just trying to see if there are any major forseeable issues before I commit to the build.
so basically what im saying there is the shape of the sealing flange on the D17 pan differs from the D16 pan. but it only differs where the rear main and oil pump are.
otherwise they are very similar.
thats good news. sounds like it could be as easy as busting out a rubber or dead blow hammer and notching a steel D17 pan. done and done.
