New member with a, just bought, 88 wagon
My names Raymond from Honolulu, Hi.. I've been lurking around for quite a while now but didn't want to register until I picked up a wagon.. And today, actually 3hrs ago, I bought an 88 civic wagon, realtime all wheel drive, 5 speed... Exterior is kinda beat up, nothing I can take care of myself. Engine runs smooth but the guy I bought it from said oil would accumulate in the #2 sparkplug tube, again nothing I can't handle...
Car has 127,xxx miles on it, minor leaks here and there. Plans are to do timing belt, water pump, all seals, valve cover gasket, all other gaskets, and all fluid flushes...
I'll get better pics tomorrow...
But later, later plans is lower it, rims, and maybe a paint job.. Was thinking a super white or a super off white... Or spray it gold again but make it looked faded and aged but sanding the corners down to the primer then spraying a flat clear over it...
pic with my 66 lincoln
I have Skunk2 front and rear camber kits brand new in the box if you're interested. Sold the wagon before I had the chance to install them. Let me know.
