"how to" tailgate lock assembly removal/installation?
Hi! So my tailgate wont lock and im getting new lock assembly. Just want to know if anyone here already did this or if we have DIY. I want to install it myself but i don't know how to do it. Thanks!
me too, i took out the screws and the cables still attached to it, i don't know how to take the cables out, i have no sight.
i did remove the long rod so i can slide out the lock from the inside. that's the only thing it holds me from taking it out. but before im able to do that i have to take out some parts to get access from the rod. to take the rod out easier i did took out the key lock because the plastic clip holding the rod is to hard to split so i have to take out the key lock and save time and aggravation.
and these how it all started.
take this panel out by removing 1 bolt from the outside
then 2 nuts from the inside
now just turn the key lock as you can see there's a rectangular hole turn it to it
you can pull it out now from the inside
this rod you have to separate from the plastic clip so you can slide out the tailgate lock
now its out from the inside, unclip the harness
then remove the cables and rod from the lock assembly
out and separated
finished!
hope this help for future reference.
http://www.hondaautomotiveparts.com/home.htm
