Help Awd Wagon Coverted to 2wd!
Hi guys wanted to see you you guys can help me out i own an awd civic wagon 89 automatic and my transmission went out? Needed a new awd tranny but was not able to find one. It was easier to get a 2wd tranny.
So my buddy did the conversion we took the drive train out needed new axles shift linkage and even put a 91 civic ecu.
Now my problem is when i drive the wagon now a s4 green flashing light doesnt come off
and i feel like it doesnt shift to the last gear because when im driving at 65mph feel like its reving hight its about 3-3.5 rpm
ALSO WHEN I DRIVE 80 ITS A 4RMP WAS IT SUPPOSE TO SHIFT TO DRIVE AT LOWE RPM
do any of you know if it a sensor or something? Has it been done?
Thank you
Thank you
So, that doesn't sound too bad. But I don't know where you were at (rpm wise) beforehand.
Good luck!
thanks alot
The code on the ECU should be 37820-PS9-XXX. The last 3 digits are less important than the middle 3. If your's says 37820-PM6-XXX, it's for a manual, and that's the issue here.
Why did you change the ECU anyways? The one from your 89 should work fine. The shifting internals of the 2WD transmission are essentially the same as the 4WD as far as the ECU is concerned.
so ur saying to get a 2wd ecu?
and what do you mean the torque converted? how do i fix revving
with new ecu would reving come down and what kind of ecu would work
thank you
appreciate help
If you want more info about them, try Wikipedia. There's tons of info about it. As far as the flashing S4 light, I'm not really sure why it's doing that. What was the model code on your 89 ECU?
should i put original 4wd ecu? flashing s4 is still going to flash
and put a new cluster since the awd wagon cluster is different then the 2wd wagon
and doesnt have the same options like the s4 light
also might the 2wd tranny i got be bad since its slips and revs high? whats the correct 2wd tranny to get?
thank you again
i just cant figure out why the s4 light dont come off
any clues how to fix?
thanks really frustrated with it and the high revving at high mph like 80
37820-pm6-a510
hopefully it is the ecu
and everythings works after
but anyone that knows anythng else about the conversion
would apreciate the help
so i got a new ecu auto 2wd from a crx hf a mp8 multi injection
and the s4 is still flashing
i finaly go what you said about the silinoid
well wen i had the awd tranny it had like 2 silinoids
so now that i converted it it has one and i conected one conection but it has like another connection
just there no where to connect?
so a came to a conclusion
maybe i need a new wire harness that connects all the way form tranny to ecu or
any ideas?
