HOW hard or easy is to install old cooler?
Hi guy i was wondering wat do u have to do to install a a/t oil cooler i got a manuall but i just want to keep it as a cruser for now and looking at the forms a/t fail from heat so can any help me where to hook it up and no wat kind of custom work to do?
At the moment you have posted on very long sentence which is rather vague, if you want help you must first help yourself.
For example:
You Wrote:
Translated to:
Hi guys, (Enter)
I was wondering WHAT do you have to do to install a automatic transmission cooler? (Enter)
I have a Manual, but I want to keep it as a cruiser for now, looking at the forums automatics fail from heat. So can anybody help me with how to install it? i.e. is there custom work involved?
So basically you want to convert your manual car to an auto?
Then because for some reason you think that cruising around will cause it to overheat you want to install a cooler?
If you want an auto I'm sure someone will be willing to trade for your manual.
If all you are doing is cruising then you want need any additional cooling as I'm very sure Honda are able to make a transmission capable of normal driving without failing.
I do have a manual tranny for it, knowing that its a very good tranny with only 34k on it:)
More effort into posts- REQUIRED
