Vibration at stop, motor mounts or timing belt?
I have vibratoin at stop and I feel it from steering wheel. I was told motor mounts need to be replaced. However, front motor mounts was replaced on oct, 2010 and others were not. Also, I cann't observe any shaking on front and rear mounts and driver side mount. Vibration reduces when I put a gear into N or P. I can notice my battery, driver side head light, and a black hose passing above alternator are vibrating. Actually, timing belt was replaced on 60,000 and it is now 11,4000. Which one causes steering wheel vibratioin at stop? bad timing belt or motor mounts or transmission mount?
Thanks
Thanks
idle speed too low?
misfire/ skip?
any fault codes?
What is the proper idle speed for RT4WD auto trans?
Is it correct idle speed?
Why do they suggest different timing belt service intervals although they have same engine?
Will it be a problem if I follow 90-91 interval? Mine is 89.
Thanks
how bad is the vibration..?? does it vibrate if your in PARK..
Whenever I shift out of park or it's at a light the car sorta just vibrates a bit (think like a cellphone in your pocket set vibrate), but I thought this was typical of most older vehicles.
Thanks, I went out and observed it carefully. Actually, it is shaking in D and R noticeably like a massage machine. It also less shakes in P and N but it still vibrates. it is stronger than my cell phone vibration thou. Also, motor mounts look pretty old. It seems previous owner never changed it. Front head lights are vibrating and driver side is vibrating stronger than right side.
I have the idle speed exactly on that mark, and it works perfectly... I´m almost sure that is 800 rpm
The rear mount I've seen on many Civics to be torn and one of the bolts are are a bitch to get at to replace.
I don't have any of the equipment needed to pull an engine and stuff, so I would need to take the parts to a shop and have them do it.
That's the rear mount...price might be higher locally wherever you're from. The other mounts should be simliarly priced. The labor to replace only one mount is 0.8 hours...ALL 4 of the mounts is around 2-2.5hours. So you can multiply that by the shop's hourly labor rate. Search my friend. Everyone was a noob once, but simple questions can be answered just by doing a tiny bit of research on your part.
Or call up a few shops and get a quote.
It's sure true that I've been asking some seriously noobish questions as of late. I guess it's what's left of my new vehicle owner freakouts getting out of my system. :roll:
Any thoughts on this?
Thanks. idle speed is correct. and when the enigne warms up enough, it more vibrates in d and R. Now I suspect a bad alternator, because recently I feel slow to start engine. Egine does not start immediately. Once I turn on all electic switches, the vibration increases. Can bad alternator cause vibration too?
Thanks
In regards to your alternator concern the best thing you could do without removing the alternator and bench testing it is perform a voltage output test. Use a voltmeter to perform this. Place the negative lead to the negative battery post and the positive lead to the nut on the alternator that attaches the cable from the alternator to the battery. I'm not sure what the exact specification is right off hand though you should see anywhere from 13 to 14.7 volts if your alternator is healthy. In terms of the vibration becoming worse when accessories are turned on, this is most likely due to bad grounds or possibly just the old wiring throughout the vehicle. Bad grounds and old wiring draw more current which in turn will put more load on the alternator. It will also likely drop the idle speed a little which will make the vibration more noticeable, especially if you have bad engine mounts. The issue of your vehicle having a hard time starting probably isn't your alternator since the alternator doesn't do much, if anything while starting the vehicle. You can actually start and run most vehicles for a short period of time without an alternator even installed, just as long as the battery is in good condition and fully charged. For your starting issue may want begin with getting your battery tested and then your starter motor too.
I found a pretty good YouTube video of someone testing their engine mounts using the way I mentioned. As you can see the front engine mount is completely broken on the vehicle.
http://www.youtube.com/watch?v=RVwZHn6ISr4
I also found clips that are very similar my engine movement. http://www.youtube.com/watch?v=av2fK6K0QYI and http://www.youtube.com/watch?v=491qLEFZ ... re=related
Thanks
Thanks for your explanation,
unfortunately, all vibration came back. The very wierd thing is that vibration disapper when I turn on AC.
Actually, after oberving my wagon several days, I could summarize symptoms.
Engine vibration, a little bit low idle, gas smell, fuel leaking from two injectors (not sure if from o rings or seal ring), poor gas mileage, soft brake pedal only when cold start after driving it turns to normal,
I suspect bad injectors, vacuum leak (as you mentioned), or bad pcv.
what do you think? please help
Thanks
Does the state you live in require a smog test for registration? If so, does your car pass smog and would you be able to provide some numbers off that smog test paper? (CO2, O2, HC, CO, NOX)
As for your mushy brake pedal upon cold start up this could be due to numerous things also. I would recommend performing a brake fluid flush to begin with and then go from there. As brake fluid ages it becomes contaminated with water since it's hygroscopic along dirt and rust. A brake fluid flush will also get rid of any air in the system and will eliminate one the variables with your concern. If a brake fluid flush does not fix the mushy brake pedal you may be looking at a new brake master cylinder (MC). There are rare occasions where the MC won't have any signs of a fluid leak, though the MC internally will be leaking. If fluid from the primary piston side of the MC is able to leak into the secondary side of the MC it will produce a mushy pedal. This may be the reason why when your vehicle is warmer the pedal becomes firm since when rubber seals become warmer they expand. Before looking too much into the variable of an internally leaking MC I would first perform the brake fluid flush.
Linked below is a website that could help you better understand how a brake master cylinder works if you're curious.
http://auto.howstuffworks.com/auto-parts/brakes/brake-types/master-brake1.htm
Thanks for all information and help!!
