Bumper help
I bought my wago with this problem and its starting to annoy me so I'm looking at fixing it but dont really know what can be done. Basically the bumber doesnt wanna stay in place and the plastic connecter peice doesnt wanna stay in the slots. I put up a pic. Help greatly appreciated
  • RaysWagon621,
    Me and my son just fixed the same thing on his bumper over the weekend, you have to go and get a new or used white or yellowish plastic piece you see on the corner. That should be all one piece and you have to remove at least half of the bumper to remove two screws holding that piece to the fender.
    Once you replace it if the car was hit...... before you assemble your bumper completely...just screw those 3 screws you see on your picture from the bumper to the white plastic piece and see if it sits flush or if you need to adjust it, what you will be adjusting is that fender tab where the white piece screws onto once your bumper sits flush again tighten everything back up.
  • just waht i was going to say
    Or Duct tape
  • jkwanusjkwanus New Wagonist
    I have same problem on bumper, so I am looking for the white plastic. However, I couldn't find the exact part and number on oem part diagram. Anybody help? Thanks
    http://www.hondapartsnow.com/Page_Produ ... ame=Bumper
  • #9 or #11 from your diagram, depending on which side you need.
    Acutally, I need the part on driver side. Which one is driver side? Thanks
  • klumklum Senior Wagonist
    i got the same problem ill do a write up this weekend if i get my tax return ill be fixing this
  • Uh, the listing below the diagram clearly states which is which.
