1988 civic wagon idle problems?
Hi all,
I am new here but I am not new to honda civic wagons. I love mine and have done allot of work to it over the years. I am having to issue that I can figure out though. I will try to explain best I can. I have a 88 civic wagon 4wd 6peed. It started doing this thing the other day. sometimes it will start up and run with out any issue ad sometimes warm or cold it will do this thing......it will act like it disengages from gear, all the sudden you will loose power and then two seconds later it will kick back in and them out and then back in. So I take it out of gear and then it will sit there and hunt for idle. if you try to give it gas it will only rev up when it is on the up cycle of the idle hunt. I am at a lost!!!! I will turn the car on and off and back again several times and then it will finally stop.
Thanks for the help.
All in all, good luck, and keep us posted on your results
